Took it a loose today and it's a lot of slack on the secondary chain (brand new) exhaust phaser going down the guide. but the tensioner side stays tight. could it be because i got it off Amazon for $140.00? but my Cloyes chain well be here Thursday.
Dec 3, 2019 at 7:03 AM
✓Experienced Mechanic
You either have a guide or tensioner that is causing the slack. That is not normal.
Can you post some pictures?
Dec 3, 2019 at 7:06 AM
BRANDON CORNELL
MEMBER
Okay, i will tomorrow.
Dec 3, 2019 at 7:18 AM
Sounds good.
Dec 3, 2019 at 7:26 AM
BRANDON CORNELL
MEMBER
Slips on both sides.
Video (Click to enlarge)
Dec 4, 2019 at 4:46 AM
BRANDON CORNELL
MEMBER
Think it's this chain:
Image (Click to enlarge)
Dec 4, 2019 at 4:49 AM
Okay, is the tensioner fully extended?
Dec 4, 2019 at 4:52 AM
BRANDON CORNELL
MEMBER
Nope only only when there's slack to that side.
Dec 4, 2019 at 7:09 AM
BRANDON CORNELL
MEMBER
The tensioner side is tight and the guide side is loose.
Dec 4, 2019 at 7:10 AM
BRANDON CORNELL
MEMBER
Then vice versa.
Is the tensioner fully extended? If it is, it will take up all the slack in the chain, not just on one side. Sounds like you have a bad tensioner.
Dec 4, 2019 at 7:17 AM
BRANDON CORNELL
MEMBER
Not strong enough to pull against the idler since its on crank and not enough to pull against cam but this me turning it over by hand so I think your right
Dec 4, 2019 at 8:35 AM
Yep
Dec 4, 2019 at 8:38 AM
BRANDON CORNELL
MEMBER
Think it was just a cheap chain didn't think $150.00 was cheap but compared to $330.00 Cloye's chain seem way tighter haven't turn it over but there's a difference in chain length Cloye's was 1/4 smaller.
Images (Click to enlarge)
Dec 5, 2019 at 8:37 AM
Hand turn the motor and check to see if it turns freely.
Dec 5, 2019 at 9:08 AM
BRANDON CORNELL
MEMBER
I will today... lets say it make 4 full turns is it fine to compression check it or do i have to start it for tensioner?
Dec 5, 2019 at 1:02 PM
It will be fine for the compression test.
Dec 5, 2019 at 1:46 PM
BRANDON CORNELL
MEMBER
Yea buddy.
Dec 5, 2019 at 6:31 PM
BRANDON CORNELL
MEMBER
Going to do it today.
Dec 5, 2019 at 6:32 PM
Keep me updated.
Dec 5, 2019 at 6:50 PM
BRANDON CORNELL
MEMBER
Brand new but bad chain was the problem.. the Cloyes is the best.. I turn it over 4-5 times its good! Thanks? Going to compression check tomorrow .
Dec 6, 2019 at 5:55 AM
Keep me updated.
Dec 7, 2019 at 12:40 AM
BRANDON CORNELL
MEMBER
Its alive! Shes running good. i am going to stick with Cloyes.
Dec 8, 2019 at 2:08 AM
Good deal.
Dec 8, 2019 at 6:50 AM
Did you post a question? I got an email but nothing showed up on my end.
