After replacing timing chain when transmission is in park the idle fluctuates
170,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
GABRIELSOLIS420
I have just changed my timing chain, my water pump,belt tensioner, and serpentine belt. but now my car is idling high then low when it is in park. when I put it in any other gear it is fine? What can the problem be now?
Sep 27, 2019 at 2:45 PM
Good morning,
Make sure you have all vacuum hoses connected. A vacuum leak will cause this.
also, make sure you do not have any air in the cooling system. Low coolant level or air in the system will cause a hunting idle as well.
Refill the radiator with engine coolant, and bleed air from the cooling system with the heater valve open.
Sep 27, 2019 at 9:35 PM
