Timing case leaking
197,000 MILES • 5.2L • V8 • AUTOMATIC
SAMANTHA135
When I pulled the water pump off of my car to replace it antifreeze is leaking out of a bolt hole on the timing case. Is this indicative of a larger problem or normal?
Aug 20, 2016 at 9:48 AM
CARADIODOC
  • 34,415 POSTS
You have a problem when coolant does not leak out of two holes. That means they are blocked by crud and corrosion. Clean those bolts with a wire wheel or wire brush, then coat the threads with silicone gasket sealer or some other type of sealant.
Aug 20, 2016 at 10:19 AM
SAMANTHA135
Thanks so much! Was being told it was a possible cracked block and wanted to verify.
Aug 20, 2016 at 11:01 AM
CARADIODOC
  • 34,415 POSTS
Nope. Those bolts go into the cooling system. That is why you should use sealant on the threads. I have owned a lot of cars with 318s and 340s, and even raced a few.
Aug 20, 2016 at 11:45 AM
