Timing belt tensioner pivot point
170,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
RICK DAVIS
I broke off the pivot that helps adjust the tensioner when set with a lock nut. I cannot fit a drill inside to fix it, is there an easy way out of this predicament I am in?
Sep 14, 2016 at 7:04 PM
HMAC300
  • 48,601 POSTS
and angle drill may get it other wise you need the pivot.
Sep 14, 2016 at 11:21 PM
RICK DAVIS
After I drill a hole exactly where the pivot point used to be before it broke off, I then could tap in a dowel pin tight enough to support the pivoting action needed for the timing belt pulley tensioner ?
Sep 15, 2016 at 6:33 PM
HMAC300
  • 48,601 POSTS
if I were putting another pin in I would use red loctite on it so it won't move you may have to wait a couple of hours for it to cure make sure the hole isn't oblong as well which is easy to do with a hand drill
Sep 15, 2016 at 11:09 PM
  • 55,766 POSTS
From Rick Davis
16 september 2016 03:19
If I'm not able to fit an angle drill where the pivot point is located to drill out at, I would have to replace the oil pump housing that the pivot point comes from am I correct?
Yes you are correct if you can get a drill in there remove the part and work on it from there.
You could try a shorter drill bit
Best, Ken
Sep 16, 2016 at 6:35 AM
