Timing belt snapped
152,000 MILES • TURBO • 2WD • MANUAL
BURNSY38
I have an eight valve Perguot engine. I was driving and the timing belt snapped. The rac said i should be okay because it has a stopper which stops any damage. Do you think if i just changed belt and kit and everything will be okay?
May 29, 2017 at 8:23 PM
HMAC300
  • 48,601 POSTS
we do not have that model in USA so no information on it. if it is an interference engine then you may have bent some valves . If it has a stopper like you say then you may be okay just replacing belt kit.
May 29, 2017 at 10:43 PM
