If you are sure the timing belt has failed, chances are there is major internal damaged done to the cylinder head and valves. It may have even damaged pistons. This engine what is know as an interference engine. There is not enough tolerance between an open valve and a piston when it reaches the top of its travel. The result, the piston hits the valve, bending it, possibly cracking the head, and possibly damaging the top of the piston.
I wish I had better news. You could replace the timing belt and check engine compression. You may have gotten really lucky, but usually that is not the case.
Here is a link that shows, in general, how a compression test is done:
If you want, I would be happy to provide all the directions for timing belt replacement or any of the engine components.
Nov 6, 2018 at 10:32 AM
