Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Engine
Timing Belt
Replace/Remove
Timing belt replacement
1992 TOYOTA CAMRY
100,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
JONT1028
MEMBER
1 POST
I'm replacing the timing belt and I cannot get the harmonic balancer off to save my life. Is there an easier way?
Apr 10, 2022 at 2:18 AM
BORIS K
Experienced Mechanic
A good video.
https://youtu.be/oNlojEgQPaQ
Good guidance.
https://www.2carpros.com/articles/how-a-harmonic-balancer-works
The harmonic balancer can be difficult to remove at times.
Cheers, Boris
Apr 10, 2022 at 10:55 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
