Timing belt broke while care was idling. I replaced it and now I get no spark to the plugs. The cams' timing marks were spot on and the crank shaft mark was TDC on a compression stroke. Is there something I need to reset or what to get the car to fire at the plugs?
Aug 14, 2021 at 10:51 AM
