Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Ram
Engine
Timing Belt
Does my truck have a timing belt or timing chain?
2004 DODGE RAM
130,400 MILES • 3.7L • V6 • 2WD • MANUAL
IBEALION
MEMBER
I'm not sure how to figure out if my listed above 1500 has a timing belt or timing chain. Do you know?
Dec 5, 2021 at 11:31 AM
SQM
Experienced Mechanic
Your vehicle is equipped with a timing chain.
The timing chain is not a maintenance item like the timing belt. However, it is recommended to replace if there is excessive play in the chain.
I have attached the guidelines of the how to check for excessive play in the chain.
Image (Click to enlarge)
Dec 5, 2021 at 11:36 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
