Timing Belt broke
197,000 MILES • 2.7L • V6 • 2WD • AUTOMATIC
SEANSTORMEH
I was driving at work about a week ago, and parked it in the parking lot and went inside to close the store down. After about a 3-4 hour wait it wouldn't start back up, or turn over. Eventually I got it towed to a shop and replaced the timing belt, serpentine belt, water pump etc but when they were finished they said that it was running rough and had white smoke coming out the back of the exhaust. I'm not sure if this would be a valve issue, gaskets, or anything else and was looking at whether it would be worth fixing it or buying a used car to get me through until I could save up enough to get these repairs done. I drove it 5 minutes or so back to work to leave it there, the engine really vibrates and rattles as you accelerate and especially when you have to stop at a stop sign or a red light.
Feb 13, 2014 at 12:28 PM
CARADIODOC
  • 34,414 POSTS
The 2.7L is an none interference engine so it's not going to have bend valves. White smoke is a sign of burning engine coolant which usually means a leaking cylinder head gasket. That is quite the coincidence it would happen at the same time, but regardless, both repairs involve removing the cylinder heads and both things will be taken care of with the valve repair.
Oct 16, 2020 at 5:29 AM
