Timing belt broke and water leaking from bottom of water pump
116,893 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
CMZANNN
  • 84 POSTS
I bought new pump and belt. Is there a way to be certain pump bad?
Aug 15, 2018 at 9:06 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Yes, there is a wear/drain hole in the bottom of the water pump that releases water from the cooling system when the water pump is worn/defective/broke. I have attached a link and pictures showing you what is involved. Hope this helps and feel free to ask questions if needed.Thanks for using 2CarPros.
Danny-
https://www.2carpros.com/articles/symptoms-of-a-bad-water-pump
https://www.2carpros.com/articles/water-pump-replacement
Aug 17, 2018 at 8:38 PM
CMZANNN
  • 84 POSTS
Danny the timing belt broke timing mark is to the right of the mark on the block I still have serpentine belt hooked up how do I get marks to align
Aug 18, 2018 at 4:43 AM
  • 55,542 POSTS
You must turn the crankshaft or camshaft by using the balancer or camshaft sprocket mounting bolt. Here is a guide that shows the marks to help:
https://www.2carpros.com/diagrams/ford/escort/2002
Look toward the bottom.
Cheers, Ken
Aug 21, 2018 at 5:44 AM
CMZANNN
  • 84 POSTS
Cannot get crankshaft pulley bolt loose also tooth on sprocket missing.
Aug 21, 2018 at 8:27 AM
DANNY L
  • 5,648 POSTS
Hello again.
The bolt the holds the Crankshaft Pulley is torqued extremely high (150-200 ft. lbs.) So a Pneumatic Impact gun or a hand tool ratchet with a large breaker bar will be needed to break it loose. As far as having a tooth missing that will need to be replaced before reassembly. Hope this helps and feel free to ask any questions if needed. Thanks for using 2CarPros.
Danny-
Aug 21, 2018 at 10:54 AM
CMZANNN
  • 84 POSTS
Got bolt out, how do I remove pulley to install new water pump?
Aug 21, 2018 at 12:50 PM
  • 55,542 POSTS
If it does not unbolt which it looks like from the picture it is pressed on from the factory just remove the bolts around the housing and the pump will come off. If I am off base here please send a picture or video of what you are talking about.
Aug 22, 2018 at 2:56 AM
CMZANNN
  • 84 POSTS
I got the water pump out. The timing belt tension-er is still on old pump. Any trick to getting it off?
Aug 24, 2018 at 9:20 AM
  • 55,542 POSTS
The tension-er just unbolts with a signal bolt in the center. If not can you upload a picture of what you are talking about?
Aug 25, 2018 at 4:45 AM
CMZANNN
  • 84 POSTS
Thanks.
Aug 26, 2018 at 6:57 AM
