After installing the timing belt, the engine will not crank?
202,412 MILES • 1.6L
TILEATHA
Put timing belt on but car will not crank?
Aug 13, 2022 at 4:07 AM
  • 55,746 POSTS
I would disenable the job because it sounds like something is off tightened on wrong or something. This is not an interference engine, so I believe the pistons or not hitting the valves. You can start by removing the drive belt to see if that helps. Let me know what you find and upload pictures please.
Aug 13, 2022 at 11:07 AM
