True or not true? If you have a broken timing belt every time you turn the engine over, you could damage the valves. Thanks, Glenn
Jan 3, 2023 at 6:29 AM
✓Experienced Mechanic
This is an interference engine. Here are the instructions on how to replace the timing belt with torque specs and timing belt marks so you can replace it yourself or see how the job is done to see what you are paying for. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Images (Click to enlarge)
Jan 3, 2023 at 10:38 AM
GLENN12345
MEMBER
Ken, did you listen to the video? Thanks Glenn.
Jan 3, 2023 at 10:45 AM
I don't see a video?
Jan 4, 2023 at 11:59 AM
GLENN12345
MEMBER
Sorry about that. Must have gone the wrong way. Let me know, thanks! Glenn
Video (Click to enlarge)
Jan 4, 2023 at 1:15 PM
Yep, it sounds like the timing belt is broken, thanks for the video. Let me know what you find.
Jan 5, 2023 at 4:46 AM
GLENN12345
MEMBER
Thanks. I will let you know. Glenn
Jan 5, 2023 at 10:19 AM
Use 2CarPros anytime, we are here to help. Please tell a friend.
Jan 6, 2023 at 4:32 AM
GLENN12345
MEMBER
Ken, I saw this today it’s a list of car makers and which ones had engines that were Interference engine or non. This screenshot is just a little section of it. I just thought I’d send this to you. thanks for everything. this car is not mine just helping someone out, we haven’t went in it yet but I’ll let you know how it turns out. thanks for your help.
Image (Click to enlarge)
Jan 16, 2023 at 1:18 PM
Wow, I didn't even know they made interference engines past 2000 thanks for the info. I will correct my post above. Thank you.
