Good evening,
Below are the steps and I will attach pictures for the repair.
This is an easy repair. You can do this yourself.
REMOVAL
1. Open and secure hood.
2. Install protective fender covers.
3. Loosen alternator assembly and remove bolts.
4. Drain cooling system.
5. Disconnect upper radiator hose and position aside.
6. Remove water pump pulley.
7. Remove crankshaft pulley.
8. Remove timing belt outer cover retaining bolt and cover.
9. Loosen belt tensioner pulley assembly.
10. Remove timing belt.
INSTALLATION
Timing Belt And Components
Images (Click to enlarge)
Nov 23, 2018 at 10:52 AM
