Timing belt?
198,103 MILES • 1.6L • AUTOMATIC • DIESEL
MOUSSELINE908766
Timing belt was done at 156411 miles And currently has 198103 miles on the clock and was done in 2022 and full kit was replaced at the time
Oct 15, 2026 at 10:49 AM
MECHTRIX
  • 583 POSTS
Vw claims its suposed to be changed every 130k mls or 5 to 7 years regardless ..a bit strange but they claim its an unusually stronger belt than the usual type i guess also diesles are generally driven at lower rpms so it supposedly wears out slower ..
anyway hope this helps good luck
Oct 15, 2026 at 6:07 PM
MOUSSELINE908766
When would you recommend to change the timing belt?
Oct 15, 2026 at 10:55 PM
MECHTRIX
  • 583 POSTS
Well let's see looks like you put about 42k on it so far since the belt was changed so next year 2027 will be 5 years since right? And it should be rolling up on 50 k mls since the change Id say start thinking about it then you have about 2 years to do it.. past that point .yeah" so id start thinking about it when you hit 50 k 5yrs..and youl still have plenty of time just to be safe hope this helps
Oct 16, 2026 at 3:48 AM
MECHTRIX
  • 583 POSTS
And jist a side note " ..
Its a bit strange the way they gyage the time limits to the wear intervals
..because on most cars it varies but its usually about 7 to 9 yrs or so ...but vw says there's is shorter but the miles are longer so its a bit confusing..if youre unsure you can call a vw dealer and ask the lead mechanic or shop manager they'd know best im sure ...good luck hope this helps
Oct 16, 2026 at 4:12 AM
