car will not start
69,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
RAINY53936
My daughter's car would not start so thought it was the starter changed that out, but still will not fire. I was told it was timing belt so I ordered the kit for it, have not got it fixed yet. My question is is that what would make it not fire?
Jan 8, 2017 at 11:51 AM
SATURNTECH9
  • 30,869 POSTS
So does it crank and not start? Meaning doe the starter turn the engine over normally and it does not start or does the starter not turn the engine over at all?
Jan 8, 2017 at 10:51 PM
RAINY53936
The motor turns over but won't start
Jan 12, 2017 at 10:54 AM
SATURNTECH9
  • 30,869 POSTS
You could pull the timing belt cover back a little and see if the cams are spining when cranking the engine over.Also have you checked for spark yet?
Jan 12, 2017 at 12:12 PM
