Remove the old timing belt tensioner pulley, idler pulley, water pump and install all new parts and belts timing belt with pictures diagrams.
Nov 16, 2024 at 3:05 PM
✓Experienced Mechanic
I attached the directions below for the entire job. I suspect there are things you won't need to do such as replace belt pulleys, but it's all there. LOL
Take a look through the directions (extensive) and let me know if you have questions.
