How hard is it to change my timing belt in a 2.0 engine automatic with overdrive before it breaks.
Thursday, April 11th, 2013 AT 6:55 PM
MECHANIC
If you never did one, it will be tough. You need a lift to perform this as well as replacing the water pump, all pulleys and tensioners. If you set the timing wrong, you may bend valves.
