Timing bank 2 over advanced codes
220,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
ANDY KRIZAK BRELLENTHIN
I was getting both P0011 and p0021 codes. I replaced both bank 1 and bank 2 cam sensors, crankshaft position sensor and both intake valve timing control solenoids. I am still getting the p0021 with a flashing SES light and it goes into a safe mode where it hits a rev limiter or cuts the fuel at 2500 rpm on the second drive cycle after clearing the codes. I cannot figure out what else it could be if the timing chain was stretched out or skipped a tooth which I highly doubt it did. would the timing be off on both of the banks? Any ideas for solutions would help. thanks
Dec 23, 2017 at 8:45 AM
STEVE W.
  • 15,378 POSTS
Very seldom will these codes be the sensors. Usually it is a mechanical problem and the sensors are demonstrated as being okay because they are setting the codes. This is a common issue on VVT equipped engines. It is most likely related to failed VVT sprockets or the chain tension-er has failed and let the chain move enough to look like the sprockets are stuck in the full advanced position. Two lower cost options first, check the oil level and change it if it is within 3,000 miles of the last oil change. The tension-er and sprockets are very sensitive of oil level and quality.
Then see if the sprockets are moving properly. If you have an O-scope you can look at the signals from the crank and cam sensors and check those against the baseline and see if the timing is changing or fixed.
If you do not you will want to find either a shop or a diagnostics pro who can test things for you.
Dec 24, 2017 at 9:49 PM
