HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Nissan
Maxima
Ignition
Timing
1991 Nissan Maxima timing
HICFROMSTICS
MEMBER
1991 NISSAN MAXIMA
6 CYL
FWD
AUTOMATIC
201,100 MILES
How do u align a new timing belt if the old one broke.
Tuesday, February 16th, 2010 AT 12:28 AM
MECHANIC
Hi there,
If this timing belt failed with the engine running you will have damaged valves in the heads, the heads will have to be removed and repaired.
Mark (mhpautos)
Tuesday, February 16th, 2010 AT 2:31 AM
Please
login
or
register
to post a reply.
Related Ignition Timing Content
1991 Nissan Maxima Timing
Put New Timing Belt On Aligned 3 Marks On Belt With 3 Sprockets. With Number One Piston At Tdc Is The Rotor On Distributor Supposed To...
Asked by
hicfromstics
1 ANSWER
1991
NISSAN MAXIMA
1996 Nissan Maxim Timing
Where Can I Find A Timing Mark Diagram For A 1996 Nissan Maxima 3.0?
Asked by
wells77
2 IMAGES
1996
NISSAN MAXIMA
Car Stalls At Random Times.
My Maxima's Engine Starts And Stops Intermittently. At Random Times, It Will Start********. Sometimes It Will Die, Other Times Not. It...
Asked by
timkojeff
1996
NISSAN MAXIMA
1986 Nissan Maxima Heat Comes On All The Time
Full Heat Comes On All The Time Even With The Control Turn To Lowest. I Checked The Vaccum Hose, And It Is Ok. I Had That Happened Before...
Asked by
pingkaic
1986
NISSAN MAXIMA
Nisson Maxima Does Jumping Time Affect The Valves
My Son's Nissan Maxima Jumped Time And The Timing Belt And Parts To Fix Cost $500. I May Can Buy A Motor With Aroud 100,000 Miles For That...
Asked by
Pam258
1 ANSWER
1996
NISSAN MAXIMA
VIEW MORE
Low Engine Power
Fix an Engine with Low Power!
Symptoms of Low Engine Power
