Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mercedes Benz
280sel
Ignition
Timing
timing adjustment information
1973 MERCEDES BENZ 280SEL
200,000 MILES
MIGUELFR123
MEMBER
1 POST
it has an idle problems, so I want double check the timing.
Apr 25, 2013 at 7:16 AM
Experienced Mechanic
Check for vacuum leaks first, then check plugs and points if fitted, i will post timing specs when i find them.
Apr 25, 2013 at 7:24 AM
Check cap leads and rotor and fuel pressure as well.
Apr 25, 2013 at 7:25 AM
Add image or video
Ask a new question
