Timing belt came loose while driving
2002 ISUZU TROOPER
13,000 MILES • 3.2L • V6 • 2WD • MANUAL
TREDO
it loosened belt while driving it just went off, does the problem cause the valves to bend?
Mar 2, 2022 at 1:27 PM
  • 110,236 POSTS
The 3.2L is an interference engine which means there may have been internal damage such as bent valves. However, I believe this vehicle has a 3.5L which is not an interference engine and should be fine. Can you please confirm that for me?
By chance, have you reinstalled the belt to see if it will run? If you have, record it cranking and upload it for me to hear. I can usually tell if there is a compression issue.
Or here is a link that explains how to test compression. If there are bent valves, you will likely have no compression in one or more of the cylinders. If you don't have a tester, most parts will lend you one.
Let me know. Also, please confirm the engine size.
Mar 3, 2022 at 10:35 AM
