Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Ignition
Timing
What is the ignition timing?
1997 TOYOTA CAMRY
100,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
PACIFICISLANDER
MEMBER
Ignition timing for this vehicle needed.
Sep 24, 2022 at 5:06 AM
SQM
Experienced Mechanic
The timing for this 2.2L engine is 8 to 12 degrees before top dead center.
I have attached the procedure below for your reference.
Let me know of any questions.
Images (Click to enlarge)
Sep 24, 2022 at 8:45 AM
PACIFICISLANDER
MEMBER
Thank you very much, Sir.
Sep 24, 2022 at 9:48 AM
SQM
You are welcome!
Sep 24, 2022 at 11:25 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
