Do I need to reset the timing after replacing the head gasket?
200,000 MILES • 4.2L • V6 • 2WD • AUTOMATIC
HEXXTER66
I just replaced head gasket on my truck listed above. I had to remove my valve covers and rocker arms. Do I need to reset timing. If so how?
Aug 17, 2021 at 1:35 AM
SQM
  • 6,383 POSTS
So you changed the head gasket and to do that you took off the head. You do not need to set timing. Unless you have to move/turn the timing chain for some reason.
Did you have to do any adjustment inside the head? If not then no other adjustment needed.
https://www.2carpros.com/articles/how-a-cylinder-head-works
Aug 17, 2021 at 2:51 AM
