crankshaft position sensor and crank position timing
180,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
SHERPARD
  • 7 POSTS
Hi guys, can you please help with timing for crankshaft position sensor and crank position? I'm really desperate now.
Mar 5, 2020 at 6:47 PM
  • 110,248 POSTS
I'm sorry, but this vehicle isn't offered in the US, so I don't have specifics on it. The 1.4L isn't available here. However, If I recall correctly, I read the intake manifold needs removed to access it. I tried to find pics online. I found one. Take a look at it. If I am correct, that is under the intake manifold and there is a coolant line blocking it as well. There should be a rubber or plastic cover over the opening. The sensor is down inside.
Here is a link that explains how in general one is replaced, but yours is a bit different because of location:
Let me know if this helps. Sorry I don't have more info.
Mar 6, 2020 at 12:53 PM
SHERPARD
  • 7 POSTS
Yes, the sensor is inside between gearbox and engine. I've opened it and did a number of setting but still nothing.
Mar 8, 2020 at 6:27 PM
  • 110,248 POSTS
Are you getting spark to the plugs?
Mar 10, 2020 at 12:41 PM
SHERPARD
  • 7 POSTS
Yes I have spark.
Mar 17, 2020 at 11:40 PM
  • 110,248 POSTS
Are you getting fuel? Will it start for a couple seconds if you use starting fluid? If you have spark, it should run unless there is a fuel issue. Most vehicles I deal with simply requires the crank sensor to be mounted. Some require setting a gap between the sensor and reluctor wheel, but timing is never done with a sensor.
Do me a favor, check to see if it will start for a couple seconds using starting fluid. If it does and then stalls, there is a fuel related issue. If it doesn't start or even try to start, record the engine while cranking and upload it for me to hear.
Mar 18, 2020 at 5:08 AM
SHERPARD
  • 7 POSTS
Okay, will do that. thanks
Mar 23, 2020 at 6:47 AM
  • 110,248 POSTS
You are very welcome. Let me know what you find. We'll figure it out together.
Mar 23, 2020 at 1:06 PM
