Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Impala
Engine
Timing Chain
Replace/Remove
No compression on all cylinders after replacing the timing chain
2005 CHEVROLET IMPALA
160,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
RANDY1955
MEMBER
I replaced my timing chain I have all the marks all in align but now I have no compression on all cylinders. can someone explain?
Apr 15, 2021 at 2:13 AM
Experienced Mechanic
Good afternoon,
Most likely you have valve damage from the failed chain. The pistons hit the valves and bent the ends and that will prevent compression.
https://www.2carpros.com/articles/how-a-cylinder-head-works
You will need a machine shop to either replace all the valves or get yourself a rebuilt set of heads.
Images (Click to enlarge)
Apr 15, 2021 at 2:34 AM
Add image or video
Ask a new question
Engine won't start
Engine overheating
