Timing
147,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
JODY MENGEL-GULISH
The timing is off. How do I re-set it? The idle is also off.
May 26, 2016 at 9:40 AM
HMAC300
  • 48,601 POSTS
ignition timing is set by computer there is no adjustment. if cam timing is off it is a belt and may have bent valves if an interference engine. if belt is problem get a kit as it replaces everything like tensioners pulleys etc.
May 27, 2016 at 12:17 AM
RENEE L
  • 1,260 POSTS
Hi Jody,
I hope this helps you.
Renee
Admin
Jun 5, 2016 at 8:01 AM
