looking for more info on the camshaft timing?
200,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
COTY0731
I watch your video on the 5.4 3v rebuild and seen when y'all where setting timing that on driver side on cam the notch was facing down and on passenger side the notch was facing up looking for more info on the cam timing.
Jan 16, 2025 at 1:01 PM
RYAN L
  • 273 POSTS
Right, there is a R and L on both with an arrow pointing up. It's the same part used on both sides.
Hope that helps!
Thanks for watching and for using 2CarPros!
Jan 17, 2025 at 4:26 AM
COTY0731
Yes but the notch in the cam itself do they both go to the bottom are on bottom and one top?
Jan 17, 2025 at 9:16 AM
  • 55,710 POSTS
I am not sure what you are saying, the notch on the camshaft goes into the actuator which has the timing a marking on it. Can you upload an image of your concern?
Jan 20, 2025 at 1:47 AM
COTY0731
Does it matter the notch of camshaft what way it faces when putting phaser on?
Jan 20, 2025 at 9:28 AM
  • 55,710 POSTS
The notch on the camshaft should match the notice on the phaser. It shouldn't matter if it is up or down as long as the noticed line up when tightening. If you upload an image, I can be sure of what you are talking about.
Jan 21, 2025 at 2:30 AM
