Trying to adjust the timing?
1995 FORD BRONCO
100,000 MILES • V8 • 4WD • AUTOMATIC
DOLLABILL25
  • 46 POSTS
Okay so I'm trying to adjust the timing and I don't know how many degrees to put it at and like work zero degrees is on the distributor like how you turn it or whatever. if you can give me any type of help on doing the timing that would be great. thank you
Jul 21, 2023 at 11:13 AM
  • 55,433 POSTS
INITIAL TIMING
1. Place transmission in NEUTRAL (M/T) or PARK (A/T) with A/C and heater in OFF position.
2. Connect an inductive timing light.
3. Disconnect the single wire in-line Spark Output (SPOUT) connector or remove the shorting bar from the double wire SPOUT connector.
4. Start engine and allow to reach operating temperature. With engine at timing rpm, check or adjust initial timing to specification.
NOTE: To set timing correctly, a remote starter should not be used. Use the ignition key only to start the vehicle. Disconnecting the start wire at the starter relay will cause Ignition Control Module (ICM) to revert to start mode timing after the vehicle is started. Reconnecting the start wire after the vehicle is running will not correct the timing.
5. Reconnect single wire in-line spout connector or reinstall the shorting bar on the double wire spout connector. Check timing advance to verify distributor is advancing beyond the initial setting.
6. Remove test instruments.
Jul 22, 2023 at 8:29 AM
