No, that won't work. When you place the crank pulley on top dead center, the number one cylinder will be at TDC. You need to time the camshafts with the crankshaft.
If you look below, I provided the directions for removing and replacing the timing belt. The directions for alignment and pics are included.
Take a look through them and let me know if this helps or if you have other questions.
Images (Click to enlarge)
Jun 16, 2021 at 1:37 PM
