steady ticking noise under the dash
180,000 MILES • V6 • 2WD • AUTOMATIC
LARRY RAVITZ
when I start the car and turn on the ignition the lights are on in the dash immediately I hear a steady ticking noise under the dash. The noise continues even when I start the car and engine is running. I know the blend door actuator on the drivers side is bad however, what could cause this ticking noise? possible blower fan cage broken?
Is the blower fan supposed to run even when the air or heater is off?
Mar 5, 2018 at 6:31 AM
Good morning.
Yes, the actuator makes that exact noise when it has failed. there are plastic gears in the actuator that strip and the ticking is the actuator trying to move as commanded.
It needs to be replaced.
Are you going to do this yourself?
Mar 5, 2018 at 10:02 PM
LARRY RAVITZ
thank you.
Mar 5, 2018 at 10:55 PM
You are welcome.
Mar 5, 2018 at 10:56 PM
