Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-250
Engine
Piston
Rod
Bearing
tight rod bearings?
1976 FORD F-250
68,000 MILES • 5.0L • V8 • AUTOMATIC
ED PEARCE
MEMBER
1 POST
rod bearings too tight can't get shims, can i use a pop can on rod cap?
Oct 19, 2022 at 5:58 AM
Experienced Mechanic
Here is the best way to remove the rod bearings, check out the video below.
https://youtu.be/RvBYxpRC464?t=407
It is a similar engine, but the process is the same. Please let us know if you need anything else to get the problem fixed.
Oct 20, 2022 at 3:40 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
