After replacing the coolant transfer pipe there is a loud ticking/slapping sound under valve cover?
120,000 MILES • 4.4L • V8 • TURBO • 2WD • AUTOMATIC
JOSLYNSHUM
I replaced the coolant transfer pipe, now there is a loud ticking/slapping sound coming from driver side valve cover when i start it. Also when i start it the noise will start the car will shake sputter and shut off after 5-10 seconds.
Aug 22, 2024 at 12:40 PM
  • 55,849 POSTS
It sounds like the engine was overheated? If so, this can cause the piston to have scored the cylinder walls, please go over this guide to see if it can help:
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
Can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on. You can upload it here with your response.
Aug 23, 2024 at 12:36 AM
