Ticking then car stalls
166,000 MILES • 2WD
MARIAHRHOPKINS
Ticking noise gets louder with acceleration and then gets quieter when slowing down, then just stalls out like it has no power. Now car will not start.
Dec 19, 2017 at 1:44 AM
Good morning my name is Roy and I will assist
From your description, it sounds like you have something in the valve train that is causing the noise. Something may be worn out or broken causing this issue.
Did you check the oil to verify the level is correct??
Dec 20, 2017 at 12:18 AM
