It appears to be coming from the #2 cylinder.
We took the valve cover off to see if we could adjust the valves but I have never adjusted the valves on this style of engine.
I am unsure if it is a rod knock or a rocker rattle/valve tap. Given the miles, I don't know how much work has been done on it.
How do I set the valve lash on this engine?
If I don/t set the valves, how do I trouble shoot the tappet/lifter to see if it is stuck?
I was also reading that too small of an oil filter can cause some oil starvation upon startup but the tapping/knocking doesn't seem to go away once its running.
Thank you!
Thank you!
Mar 23, 2016 at 9:06 AM
