Ticking noise
1,670,007 MILES • V6 • 2WD • AUTOMATIC
CHASTEENMYRA42
I was told it was a lifter when I bought the car but a friend told me it sounds like timing chain. It’s coming from the front end.
Dec 28, 2019 at 5:01 PM
SCGRANTURISMO
  • 4,897 POSTS
If the noise is coming from the front of the engine then chances are that it is going to be the timing chain or the timing chain damper. Your vehicle's engine is an interference engine, so I would get this job done ASAP. In the diagrams down below I have included the instructions for the removal and installation of the timing chain and sprockets for your vehicle from the manufacturer. Please go through this guide and get back to us with how everything turns out. Happy Holidays.
Thanks,
Alex
2CarPros
Dec 28, 2019 at 8:38 PM
CHASTEENMYRA42
But could it still be the lifter? Or maybe new plugs?
Dec 29, 2019 at 4:25 AM
TOUGHDIVER
  • 226 POSTS
A ticking noise in the engine could be a number of things, Note the timing chain usually makes a rattle type noise, A collapsed lifter will make a ticking type noise, Either noise will be in-sync with engine rpm's. Low oil pressure or wrong oil filter is usually the culprit. I'm attaching a diagnostic chart and some information on engine noise. And lifter replacement below.
Please let us know what your problem is and what you did to correct it.
Valve Lifter Replacement
Removal Procedure
1. Remove the valve rocker arm cover.
2. Remove the lower intake manifold.
3. Remove the valve rocker arms and pushrods
4. Remove the lifter guide bolts.
5. Remove the lifter guide.
6. Important: Place the valve lifters in an organized order to ensure that they are installed in the same location from which they were removed.
Remove the lifters.
Installation Procedure
1. Coat the valve lifters using prelube GM P/N 1052367 (Canadian P/N 992869) or the equivalent.
2. Install the valve lifters in their original locations.
3. Install the lifter guide.
Apply threadlock GM P/N 12345382 (Canadian P/N 10953489) or the equivalent to the lifter guide bolt threads and install the bolts.
^ Tighten the bolts to 10 Nm (89 inch lbs.).
4. Install the valve rocker arms and pushrods.
5. Install the lower intake manifold.
6. Install the valve rocker arm cover.
7. Inspect for leaks.
Thank you
Joe Terwlliger
Dec 29, 2019 at 8:20 AM
