Ticking noise coming from the purge solenoid
220,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
YAZIDAN
  • 141 POSTS
When i opened the hood i could hear a rapid ticking noise from the purge solenoid. Is it normal?
Feb 22, 2022 at 7:01 AM
SQM
  • 6,383 POSTS
The purge solenoid makes the ticking noise means it is functional. If it becomes loud, then it is a sign of an internal failure of the solenoid. You should not hear it from inside the vehicle.
It can also make rapid ticking noise if there is a leak.
That will typically turn on the check engine light.
Is your check engine light illuminated?
If so scanning and retrieving the code can help determine if there is an issue with the emission system or purge solenoid.
I have attached the solenoid test procedure below for your reference.
Feb 22, 2022 at 11:05 AM
YAZIDAN
  • 141 POSTS
no, the check engine light is not on. but i noticed the long-term fuel trim is high +13.
Feb 22, 2022 at 11:09 AM
SQM
  • 6,383 POSTS
The fuel trim becomes high when the PCM thinks that the air fuel ratio is too lean and adding fuel to bring the mixture to within the correct range.
Are you experiencing any drivability issues?
Feb 22, 2022 at 11:12 AM
YAZIDAN
  • 141 POSTS
no, drivability issues. Can a bad purge solenoid cause high fuel trims?
Feb 22, 2022 at 11:20 AM
SQM
  • 6,383 POSTS
Yes, a faulty purge solenoid can impact the fuel trim. You can try the test for functionality of the solenoid.
Feb 22, 2022 at 11:30 AM
AL514
  • 5,700 POSTS
Hello SUSPECCTT27, you will have to start a new posted question for this please. Then a technician will be able to reply. Thank you.
Here is the link for starting a new question, make sure you are logged into the site before clicking on the link:
May 10, 2023 at 4:04 AM
