ticking/knocking sound
2005 DODGE STRATUS
103,000 MILES • AUTOMATIC
DREARUSH_72
I had to have the timing belt replaced so had a friend do that for me I drove it bout a couple miles after he was done it wasn't right so then took it to a shop he was only 2 teeth off from having it timed right however after that my engine had a slight tick tick tick sound was told that's normal all engines get a ticking sound well its a yr later now it has gotten to be a ticking/ knocking sound so what do I do
Jan 7, 2016 at 2:56 AM
HMAC300
  • 48,601 POSTS
depending on engine it may have bent a valve if timing wasn't set correctly. it may be a lifter as well
Jan 7, 2016 at 4:03 AM
DREARUSH_72
Is this a serious issue I am still praying on this car
Jan 8, 2016 at 3:59 PM
HMAC300
  • 48,601 POSTS
a bent valve is serious but if it'snot misfiring then it's probably ok. the other may be the lifter so it will have to have a pro check it out. because I can't hear it it's best to have checked locally
Jan 8, 2016 at 9:50 PM
