Ticking coming from where intake is?
158,000 MILES • 1.4L • 4 CYL • TURBO • 2WD • AUTOMATIC
KINGJD123
  • 104 POSTS
I just did my purge valve spark plug and injectors, i am still getting a fast-ticking noise like lifters. is that common? The car runs fine, no check engine light just want to make sure it doesn't leave me stranded i commute 60 miles a day.
Feb 19, 2024 at 10:37 AM
BORIS K
  • 836 POSTS
The purge valve usually emits a load ticking noise when it is actuated by the ECM.
This is normal.
See video:
https://www.youtube.com/shorts/ylxO_SslQIY?feature=share
Just unplug the valve while it is making the ticking noise, the noise should stop.
Cheers, Boris
Feb 20, 2024 at 12:31 AM
