Thumping
2003 FORD ESCAPE
156,000 MILES • 3.0L • V6 • 4WD • AUTOMATIC
WILLIAM3816
  • 10 POSTS
Hello, there is a thumping/shaking sound that comes and goes, its most noticeable at about 20mph and fades away at about 35mph. But heres the catch, it doesn't do it every time. Some days its fine and some days its not... Any ideas?
Apr 5, 2016 at 6:22 AM
WILLIAM3816
  • 10 POSTS
Forgot to mention, it only happens under acceleration/hard braking. It will go away immediately after i take my foot off the gas but as soon as it put my foot back on the gas it begins again
Apr 5, 2016 at 6:26 AM
CJ MEDEVAC
  • 11,004 POSTS
FROM PAST EXPERIENCES WITH MY JEEPS AND OTHER FOLK'S JEEPS
MINE TEND TO SORTA CHIRP WHEN THEY ARE IN THE BEGINNING STAGES OF WORN-OUT-NESS, BUT ONLY WHEN I LET UP OFF OF THE GAS. AS THEY GROW WORSE VIBRATIONS OCCUR, IF IT GETS WORSE THAN THAT, THE YOKES/ PINIONS/ SEALS/ SHAFTS MIGHT GET DAMAGED!
CHECK YOUR UNIVERSAL JOINTS!
I HAVE SOME CRUDE PICTURES OF HOW, WITH MY 1946 WILLYS JEEP AS THE DEMONSTRATOR. SEE BELOW
KEEP US POSTED!
THE MEDIC
Apr 5, 2016 at 11:46 AM
WILLIAM3816
  • 10 POSTS
I replaced the u-joints and center support bearing. It dampened it but after a couple miles it returned
Apr 5, 2016 at 12:55 PM
CJ MEDEVAC
  • 11,004 POSTS
FRONT AXLES?
THE MEDIC
Apr 6, 2016 at 8:57 AM
WILLIAM3816
  • 10 POSTS
No movement in them. Boots are not cracked
Apr 6, 2016 at 11:46 AM
WILLIAM3816
  • 10 POSTS
Heres a link to a video that I recorded of the sound http://youtu.be/dhbVpI2dqYk
Apr 6, 2016 at 3:27 PM
CJ MEDEVAC
  • 11,004 POSTS
I'VE ASKED SEVERAL OTHERS
HERE'S THE THOUGHTS
#1 FELLER- LOOSE SPARK PLUG
#2 FELLER- ROCKER ARMS
MY NEXT GUESS- BACK IN ABOUT 1983---I'M PASTING IN THAT PART OF AN ANSWER FROM THIS OLDER POST
https://www.2carpros.com/questions/1984-jeep-cj7-grinding-noise-from-front-drivetrain
PASTING
ONCE WE WERE CRAWLING AROUND AT FT. BARTLOW (SAVANNAH, GA.) AT THE TIME, AN "UN-EXCAVATED" CIVIL WAR SHORE BATTERY--SORTA ABANDONED---WE ONLY FOUND IT THROUGH OUR SUPER AIRBORNE RANGER NAVIGATIONAL SKILLS!
SEEMS THAT FT. PULASKI (THE SHOW-CASE NATIONAL MONUMENT, HEADED TOWARD THE BEACH) HAD ANCIENT MAPS OF THE AREA DISPLAYED---AND THEY SHOWED THE BATTERY ON THEM--BUT IT WAS GROWN OVER AND BURIED IN SAND---KINDA LIKE A LOST CIVILIZATION!
WE CRAWLED OVER THE "MOATS AND BARRICADES" A LOT (MEANT FOR NON JEEP PEOPLE!)AND PLAYED IN THE BATTERY FROM TIME TO TIME. USUALLY FEMALES WERE INVOLVED!
THERE WAS A DEEP DEPRESSION IN THE MIDDLE OF THE FORT (OVERGROWN AND JUST LOOKED FUNNY. SAVANNAH IS FLAT!), WE CALLED IT, "THE DEVILS BOWL"
MY BUDDY HAD A CJ7 AND HAD MORE RISK IN HIM, THAN I, SO HE WENT IN IT 1ST
WHEN HE CLIMBED OUT, I WENT (CJ5). WHEN I TRIED TO CLIMB OUT, I GOT A TERRIBLE GRINDING NOISE.I FINALLY HAD TO BACK OUT, TO GET OUT
ON THE WAY TO THE BARRACKS, MAYBE 10 MILES AWAY, I EXPERIENCED A LOT OF VIBRATION. NO GRINDING
WHEN I INVESTIGATED IT THE NEXT MORNING, I FOUND MY BOLTS THAT ANCHORED THE TRANNY TO THE SKID PLATE WERE GONE!
THE REAR OF ENGINE/ TRANNY/ AND TRANSFER CASE WERE SLIDING LEFT AND RIGHT ON THE SKID PLATE----THE GRINDING WAS MY FRONT DRIVE SHAFT (WHEN IN 4x4) HITTING SOMETHING ON THE FRAME (WHILE IT WAS TURNING) WHILE IT WAS SLID TOWARD THE PASSENGER SIDE!
WHAT A SENSELESS STORY (YOU SAY!)----ANY POSSIBILITY OF SOMETHING SIMILAR TO THIS?
OK- MORAL OF THIS PASTE
YOUR ENGINE "TORQUES" ONE DIRECTION WHEN GOING FORWARD(UNDER LOAD)-THE OTHER WHEN IN REVERSE (OR LETTING OFF THE GAS SUDDENLY OR BRAKING)
MAYBE A MOTOR/ TRANNY MOUNT IS LOOSE/ DETERIORATED
MAYBE THE ENGINE IS NOW TORQUING BEYOND THE LIMITS IT SHOULD
THIS IS ALLOWING THE PULLEYS/ BALANCER/ EVEN THE FRONT AXLE (OR IT'S PARTS) TO COME IN CONTACT WITH ANOTHER FIXED PART WHILE THEY ROTATE
HENCE
LOOK FOR FRESH SHINY PLACES WHERE IT HAS BEEN BEATING ON THE OTHER PART
WHACHA THINK?
THE MEDIC
Apr 10, 2016 at 12:42 PM
WILLIAM3816
  • 10 POSTS
Oh my god, those symptoms are spot on to what I'm experiencing!! .. I'm not much of a car guy, so where is the transmission mounts/engine mounts and is this easy to fix? Thanks!!!
Apr 11, 2016 at 9:58 AM
WILLIAM3816
  • 10 POSTS
Also how do i check the spark plugs and rocker arms?
Apr 11, 2016 at 9:59 AM
CJ MEDEVAC
  • 11,004 POSTS
LET'S PUT THE SPARK PLUGS AND ROCKERS ON THE BACK BURNER
WHAT YOU NEED IS SOMEONE WITH, AT LEAST, SOME EXPERIENCE TO LOOK AT THE SITUATION
A "FREE"! LOOK-SEE MIGHT BE THE FELLER BEHIND THE COUNTER AT THE AUTO PARTS STORE! (THE ONES THAT HAVE THE BIG TRUCKS OR MUSCLE CARS THAT DO THEIR OWN WORK WOULD BE THE ONES TO TALK WITH
THEY CAN SHOW YOU THE MOUNT LOCATIONS AND MIGHT EVEN SEE SOMETHING THAT YOU AND I CAN'T
SEE IF THEY WILL LOOK UNDER YOUR HOOD WHILE YOU HOLD THE BRAKE AND SHIFT FROM FORWARD TO REVERSE (THIS WILL TORQUE THE MOTOR)
IF IT SEEMS EXCESSIVE, MAYBE YOU CAN GET THEM TO POINT OUT WHERE MOVING PARTS MIGHT RUB
MANY TIMES THEY WILL CRAWL AROUND AND LOOK FOR THE RUBS (OR PROBLEMS)
TAKE A GOOD STRONG FLASHLIGHT AND MAYBE A HAND MIRROR WITH YOU (NO NEED IN THE ASKING IF THEY CAN'T SEE TO THE BEST OF THEIR ABILITY!)
(MY BEST-US GUESS WOULD BE AXLE RELATED, SPINNING AGAINST METAL- BUT THAT'S JUST ME DOWN HERE IN SOUTH CAROLINA!)
REPORT BACK ANY FINDINGS!
BELOW IS/ WAS MY '79 JEEP #2 (HAD IT FROM '83 TO '87), THE ONE THAT THE TRANNY ANCHOR BOLTS FELL OUT OF!
THE MEDIC
Apr 11, 2016 at 11:02 AM
WILLIAM3816
  • 10 POSTS
Just some extra information for you, the "thumping" is mostly felt in the center console, it feels as if something is spinning and hitting something and it intensifies when engaging four wheel drive. When its in 4x4 it goes crazy it bangs and thumps horribly. But hears something I'm confused about, I don't loose any power, i can still accelerate without a problem, it just thumps and shakes like crazy until i get it around 35mph
Apr 12, 2016 at 10:12 AM
WILLIAM3816
  • 10 POSTS
Just to mention, my car is a fwd car unless 4x4 is engaged
Apr 12, 2016 at 10:14 AM
CJ MEDEVAC
  • 11,004 POSTS
ROGER
HOW 'BOUT THE AUTO PARTS STORE GUYS LOOKING AT IT?
LEMME KNOW WHAT THEY SEE!
THE MEDIC
Apr 12, 2016 at 12:14 PM
WILLIAM3816
  • 10 POSTS
The guy who looked at my car, he said the problem is from my rear tires being severely "cupped" and have flat spots, which they in fact are cupped and developing flat spots.
Apr 13, 2016 at 12:48 PM
CJ MEDEVAC
  • 11,004 POSTS
WOW!
THEY SURE DID MAKE SOME RACKET!
I RECKON I STILL WOULD NOT HAVE GUESSED THAT EVEN IF I WAS IN THE CAR BESIDE YOU!
WHAT'S YOUR PLAN NOW? NEW TIRES?
AN ALIGNMENT MIGHT KEEP IT FROM DOING IT AGAIN
KEEP US POSTED
THE MEDIC
Apr 15, 2016 at 11:32 AM
