There is a thumping noise when acclerating?
180,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
BRIBRI4275
  • 24 POSTS
My vehicle listed above makes a thumping noise when I accelerate. Sounds like a flat tire but it's not. I added oil to the differential, and it still does it. I checked the u joints but I'm not sure how they are supposed to be as far as working. Thought it might be the wheel bearings; there is a little play with the wheel in terms of spinning. Please help if possible.
May 28, 2025 at 8:46 AM
  • 55,682 POSTS
Can I ask you to respond to these which we helped with?
https://www.2carpros.com/questions/engine-problems-1974286
https://www.2carpros.com/questions/engine-problem-63295975
https://www.2carpros.com/questions/fuel-injector-problem
May 29, 2025 at 5:05 AM
