Thud in front left side
120,000 MILES • 0.6L • 6 CYL • 2WD • AUTOMATIC
CHERIEJO
When I’m at a stop , the take off my left front make a single thud.
Sep 21, 2019 at 10:38 AM
This is most likely a bushing or other suspension component that is worn out. Unfortunately there is no easy way to check these other than inspecting them for cracking or wear.
The most common thing that fails on these are engine mounts. This can cause a clunking noise. I would suggest lifting the hood and having someone shift from Park to Reverse then drive, and back. If the engine rocks a good bit then the engine mount has failed. If this is not it then you need to look at the suspension components to determine if they are worn. Here is a guide that will help:
https://www.2carpros.com/articles/popping-noise
https://www.2carpros.com/articles/lower-control-arm-bushing-replacement
Let me know what you find and we can go from there. Thanks
Sep 21, 2019 at 11:22 AM
