At times it seams to starve of fuel , let up on gas and it will even up. but it runs smooth.
Jun 10, 2017 at 2:57 AM
CJ MEDEVAC
✓Experienced Mechanic
Check engine light on?
Last time it had a fuel filter?
The Medic
Jun 10, 2017 at 4:01 AM
STEVE W.
First thing would be to check the fuel pressure, low pressure due to a failing pump or clogged filter can cause this. You can "borrow" the tools to test the pressure at many auto parts stores. You should have between 60-65 psi.
Jun 10, 2017 at 4:03 AM
HARRY P
I am with Steve, check the fuel pressure. Having had two Blazers with the same fuel pump as yours, I have replaced both of them. And they went bad right at the 150,000 mile mark. Also, they are a known common problem with S-Series trucks (Blazers, Jimmys, S-10s, etc).
Jun 10, 2017 at 7:47 AM
RENEE L
MEMBER
Hi TERRY KAHN,
If you are interested in checking your vehicle's fuel pressure yourself here is a helpful link to an article from this site with step by step instructions and pictures explaining the process of checking the fuel-system-pressure-and-regulator.
