Throttle valve control
330,000 MILES • 3.0L • 6 CYL • 2WD • MANUAL
JOHNNY MILLS
  • 12 POSTS
I am not getting power to the throttle valve control.
Mar 15, 2018 at 11:11 AM
Good morning.
Do you mean the Idle control valve?
Mar 15, 2018 at 8:07 PM
JOHNNY MILLS
  • 12 POSTS
Yes.
Mar 15, 2018 at 9:04 PM
The red wire to the IAC is a common voltage sent to all the injectors as well. It comes from the fuse block.
Does the engine run?
Did you check for power with key on engine off?
Mar 15, 2018 at 9:47 PM
JOHNNY MILLS
  • 12 POSTS
The engine light is on i checked the plug to the throttle control with the ignition on and there is no power.
Mar 15, 2018 at 10:02 PM
JOHNNY MILLS
  • 12 POSTS
Yes it runs. i am thinking the white wire ground may have a bad connection. What do you think?
Mar 15, 2018 at 10:04 PM
Okay, the red wire should have power and it comes from a splice that also feeds the injectors. it is the same color wire. check for power to the injectors on the red wire.
What is the code?
Mar 15, 2018 at 10:06 PM
no, you need power before you can think a ground.
Mar 15, 2018 at 10:08 PM
JOHNNY MILLS
  • 12 POSTS
Okay and if no power what is next?
As I just stated, check for power to the injectors.
What code number?
Mar 15, 2018 at 10:09 PM
JOHNNY MILLS
  • 12 POSTS
Okay.
JOHNNY MILLS
  • 12 POSTS
I think he said po 0505 something like that. he said its the control valve. i put a new one on and same problem so i checked the wires and no power. do these wires go to a pigtail behind the intake?
Mar 15, 2018 at 10:13 PM
JOHNNY MILLS
  • 12 POSTS
The truck runs its just that the control valve is not getting power.
Mar 15, 2018 at 10:15 PM
It goes to a splice that ties the injectors as well. let me see if I can find the splice.
JOHNNY MILLS
  • 12 POSTS
Thanks the truck runs its just no power to the idle valve control.
Mar 15, 2018 at 10:17 PM
The splice is back by number six injector harness. C122 is the connector.
Mar 15, 2018 at 10:20 PM
JOHNNY MILLS
  • 12 POSTS
So I will need to take the intake manifold off to get to it.
Mar 15, 2018 at 10:23 PM
JOHNNY MILLS
  • 12 POSTS
The diagram you sent is too small to read. i am using my phone to communicate do not have home internet thanks anyways.
Mar 15, 2018 at 10:25 PM
You can run a jumper wire from the red wire from the injector to the red wire of the IAC and see if it makes the valve work.
Mar 15, 2018 at 10:29 PM
JOHNNY MILLS
  • 12 POSTS
Okay I will try that. I really appreciate the information.
Mar 15, 2018 at 10:30 PM
You are welcome.
Mar 15, 2018 at 10:33 PM
