Throttle high
190,000 MILES
YVONDALOPEZ
Your question: "I ha e a 97 Saturn sc2 it wouldn't crank I know sylanoid switch is bad but I tapped it crank right up but reved full throttle I replaced throttle position sensor tapped on starter it cranked right up and it still full throttle won't stop"
Apr 24, 2013 at 3:56 AM
JDL
  • 16,098 POSTS
Take the throttle cable loose from throttle body and cruise, any change? See if throttle valve is closing all the way?
Clean throttle-body and idle air, see if it helps?
Like you said, sounds like you need to replace starter.
Apr 24, 2013 at 4:22 AM
