experiencing subtle but consistent hesitation
150,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
SFINA
  • 15 POSTS
I have experienced subtle but consistent hesitation since 8/22/16. At 11:00 am on 9/12/16 while on the freeway the transmission seemed to go into fail safe locking in forth gear. Five miles later was a quick jolt, major rpm drop and what felt like a complete loss of throttle. I was able to maintain thirty mph with the pedal to the floor and a lot of hesitation.
Once off the exit I could only hit twenty mph. Stalled at stoplight but restarted. Taking off from stoplight to fifteen mph was painfully slow. As I turned the wheel to pull into a parking lot I lost more power and high pitch belt chirp.
I had it towed to my house on a flatbed.
Once home I spent the day troubleshooting and tuning up. It continued to fire up at the end of the night. Still major throttle hesitation and no way could I pull it out of the driveway.
The next morning it will not start. Still will not. Seems to be getting plenty of gas (manually depressed valve on the fuel rail in the engine compartment while starting and got a fast steady spray of fuel). You can smell fuel when cranking. Wont fire.
Below I have detailed the troubleshooting done to date. I would appreciate any help. I am at a loss.
Worthy of Note: I replaced a bad fuel pump six months ago. I replaced it with a used $60.00 pump from the junk yard. When removing the old pump I broke the plastic pin that secures the gas line to the pump. The line has a ridge it the line slides over though. Twice in the past four weeks the line has come off while idling for fifteen plus minutes. Each time I simply slipped it back on.
Worthy of Note Two: The exhaust pipe separated from the catalytic converter roughly three or four weeks ago also. Possibly a combination of higher than usual heat and rust.
Changed all eight spark plugs (gap at .040) two right spark plugs were black and wet. The rest were dark and used up I am surprised they still worked. The gap was more than my gap tool. I have never changed them.
Changed air filter - old filter K&N washable but was so blocked up I just bought a regular filter.
Changed oil and filter. The dipstick was not showing any oil but the pressure gauge was half way. No signs of leaking and nothing in the antifreeze
Removed serpentine belt and scrubbed with wire brush. Belt looks good.
Check all pulleys - no play and no noise except the tensioner which had a slight noise to it.
Lubricated Pulleys and steering components
Break and power steering fluid good. power steering reservoir has been leaking for some time but I have not fixed it. It is a slow leak and I keep it at the right level.
Removed air intake. Throttle body butterfly valve had a lot of crud on it. I sprayed it with CRC Throttle body and air intake cleaner as I moved the valve back and forth. I wiped the crud away with a rag.
Added Sea Foam engine treatment to gas tank. Gas tank half full. I have problems with the slightest amount of water in the gas so I also added a half bottle of Freeze moisture remover to the gas.
Reviewed hoses and electric wiring for any visible damage or lose connections. Tightened anywhere there was a ground I could find.
Checked all fuses
Removed positive battery terminal for twenty seconds to clear codes etc.
trickle charged battery overnight at two amps.
Sep 14, 2016 at 4:37 AM
HMAC300
  • 48,601 POSTS
first thing; belt and tensioner is recommended replacement at 60,000 miles. make sure battery is in good condition and will pass a load test. try resetting security system and finally do wiggle test on crank sensor, may be a bad connection and check fuel pressure with a gauge auto parts rent it.
Sep 14, 2016 at 5:08 AM
SFINA
  • 15 POSTS
Thank you for your response. The batter tested at 13.2 and it also tested at 12.4 with the engine cranking. How do I reset the security system.I can't find an answer to this. I will get a fuel pressure guage as you suggested. I pulled the mass airflow sensor out this morning and it's relly dirty. I'm cleaning it now. I appreciate your help. Please let me know if there's anything else you can hink of. I'm a a loss here.
Sep 15, 2016 at 9:41 PM
HMAC300
  • 48,601 POSTS
if you have another key try that not a new key. if not a mechanic will have to scanit
Sep 15, 2016 at 11:15 PM
SFINA
  • 15 POSTS
I found the Mass Airflow sensor was blue on one side and black on the other facing the air filter. Caked in oil. I cleaned it using rubbing alcohol in a bag. It now acts like it wants to fire but still isn't firing. Any suggestions? Also I didn't think I had a security system HMAC300.
Sep 19, 2016 at 3:11 AM
HMAC300
  • 48,601 POSTS
all vehicles since at least 1997 have security or anti theft systems. Government requirement.ou rmanuals do cover security resets that is why I said look online or if you have a manual it will tell you there.
Sep 19, 2016 at 3:57 AM
