Throttle cable replacement
150,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
LYNN GONSER
The throttle cable snapped and I need to know how to replace it.
Jul 6, 2019 at 1:12 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
I've attached step-by-step pictures below that will guide you. Hope this helps and thanks for using 2CarPros. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Danny-
Jul 6, 2019 at 9:56 AM
LYNN GONSER
I was changing the throttle cable and had to remove the throttle control lever. Now that I'm ready to put it back on I can't remember how to get the spring on right. I would really appreciate some instruction on how to put the throttle control lever back on.
Jan 4, 2021 at 1:58 AM (Merged)
SCGRANTURISMO
  • 4,897 POSTS
In the diagrams down below I have included instructions for the removal and installation of your vehicle's throttle cable. There should be what you looking for in there. Please get back to us with how everything turns out.
Thanks,
Alex
2carPros
LYNN GONSER
I got it and everything is working fine! Thanks for your help.
  • 55,710 POSTS
SCWICKEDSTANG is one of our best. Use 2CarPros anytime, we are here to help. Please tell a friend.
