No codes in ECU for anything. Sparkplugs have plenty of life left.
Is it possible for the throttle body valve motor to not throw a code yet not be able to open enough allow a smooth idle? This car does not have an idle control valve.
Idle is "usually" smooth. Every few random seconds the rpms dip a few hundred rpm and goes immediately back up to normal idle. The car does not feel like it is about to die. After x number of random seconds, it does it again. Sometimes it will not even do it at all. It simply sputters for a very brief moment causing a minor jolt in the car.
It happens when in gear (automatic) or in neutral. When in neutral, it is barely noticeable since it is not jolting the car.
Once you are driving, the car is perfectly smooth with no sputtering. This random issue only occurs during idle.
Nov 30, 2019 at 12:40 AM
