throttle body smoke
113,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
NATEM
whenever i go to start i get a really rough turnover but no start unless i pull the injector and shake it clean of gas and reseat it. when it does start it idles super rough with a ton of shake and shuts down after about 2 seconds with a pop and a bunch of white smoke from the throttle body. i just replaced injector and same problem. seems like no fuel but injector is flooded when i pull it.
Jul 14, 2020 at 9:33 AM
  • 110,248 POSTS
The white smoke sounds like it is backfiring. Is there any reason to think there could be a timing related issue?
Here is a link that discusses similar issues:
https://www.2carpros.com/articles/engine-backfires-while-running
Also, have you checked fuel pressure to make sure the regulator is working and pressure isn't too high? Here is a link that explains how it is done:
Here are the manufacturer's specs for pressure:
1988 Chevy Truck S10/T10 P/U 2WD L4-151 2.5L
Fuel System Pressure Specifications
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Pump Fuel Pressure Specifications Pressure, Vacuum and Temperature Fuel System Pressure Specifications
FUEL SYSTEM PRESSURE SPECIFICATIONS
FUEL PRESSURE:
Ignition ON Engine OFF .................... 62-90 kPa (9-13 psi)
One last thing. If you haven't already, check to see if there are any diagnostic trouble codes. This truck has an OBD1 system that doesn't require a scan tool. All you need is a short jumper wire or even a paper clip. Here is a link that explains how to test for codes. Also, there is a list of codes and their descriptions after the directions.
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
_________________________
Let me know what you find.
Jul 14, 2020 at 1:41 PM
