throttle body relearn?
260,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
KAPFERJB
replaced the throttle body with new TPS and gas pedal with sensor, I did the throttle relearn with my scanner and it worked after the third time. it went right back into limp mode, so I don't again. And again. again. so, after the 7473rd time it took and I drove for about 45 minutes and it ran okay, it was running a little rough but that's normal while it learns. I stop, check things out and kill the engine. I start up to leave, limp mode and that was a week ago.
I bought the GM professional shop manual, 11800 pages worth and I guess the truck has to be within certain parameters or the relearn won't work. I can clear the codes I need to clear, but they immediately come right back so I can't do the relearn.
I've hit my wall, where do I go from here? I have a great scanner with plenty of capability but i'm lost.
any ideas??
thank you!
Jeremy k .
Feb 9, 2023 at 1:51 AM
  • 110,248 POSTS
Jeremy,
I'm not sure what all was done, but it sounds like a lot. When it goes into limp mode, what codes are present? If you are in limp mode, there should be diagnostic trouble codes present.
Can your scanner read can-bus codes?
Feb 9, 2023 at 7:23 AM
KAPFERJB
i can upload the diagnostic report.
http://thinklink.api.thinkcar.com/Home/ThinkCar/thinkToolReportDetail/diagnose_record_id/76c641d9jqtZnROMKwKwoGOM/report_type/TC/l/en-us?style=12
If this doesn't tell you what you need to know tell me and I will give you what you need to know. thank you!
Feb 9, 2023 at 7:54 AM
  • 110,248 POSTS
Are all of these codes still present? Is the battery fully charged? Was there any damage to any of the wires to the TB damaged in any way or corroded? Everything indicates low voltage.
Feb 9, 2023 at 10:26 AM
KAPFERJB
i haven't seen any damage to anything so far and i run dual batteries and keep them charged. i can run it for a while to be positive that they are at full capacity and try again.
As for the codes they were present last time i scanned but will check again today.
Feb 12, 2023 at 2:13 AM
  • 110,248 POSTS
Thank you for the update. Let me know what you find. I'm interested in knowing.
Feb 12, 2023 at 11:50 AM
